freakycody
- Nov 24, 2003
Okay, i am having a big problem with my PC. It randomly freezes at certain points. Sometimes it will freeze in like 10 minutes after rebooting, or 2 hours. it is really random. I can be doing stuff and it will freeze and i could have only AIM running and it will freeze. I am not sure what to do. Especially since i just reinstalled windows XP home (tried Pro but every time it got to registering componets on the install screen it froze). I thought a fresh install would help, but it did not. I checked my ram and it is okay (i used another persons ram and it still did it. So any suggestions would be great. I am thinking about borrowing freinds video card and swapping it in and seeing if that helps, tell me if that is worth doing. Thanks for any info you can provied
PC Stats
2800+ AMD
Aopen AK79D-400VN
2x256 elixir ddr-400
128mb 9800 Pro
80gig Maxtor
PC Stats
2800+ AMD
Aopen AK79D-400VN
128mb 9800 Pro
80gig Maxtor
