OlIv0rIolI
- Dec 2, 2005
I purchased the xonar essence card a week ago from zipzoomfly and got it this morning. I proceeded to install it.
Before opening the shipping box it came in, i noticed that the object inside is moving around a bit. When I opened the box. I saw that zzf did a terrible job of packing. They put a few air bags in it, and it wasn't even enough to keep the product from moving around much less the fact that one airbag flattened out . I felt a little dread, but whatever, The card is not some HDD and it is saftely tucked in the asus plastic packaging, so it shouldn't be effected in any way.
When I slide the card into PCI-E, I noticed that it isn't a tight fit like with the 16x card and you can push the card forward and backward parrell to the long axis of the pcie slot. I thought it might have something to do with pcie1x being very small. Not sure about it.
Anyway I turned on my computer into winxp64 and....nothing. I went into the device manager and I don't see anything new. I installed the cd driver anyway because I thought that might fix it. When installation is complete it saids "Please connect your sound card"?????. I realized I need to turn off onboard sound so I restarted, did that and it still doesn't work. I tried the only other pcie1x slot and no luck. And yes I did connect the molex power to the sound card. My motherboard is in my sig.
Also I have duel boot winxp64 and vista64 and none of them works. Please help.
