I'm purchasing an XBox 360 very soon and plan on getting the wireless adapter to go with it, but I need to get some recommendations on a good wireless router that works with the XBox live network. Obviously the XBox live website has a small list of compatible routers, but the list is very small and also looks outdated as the routers listed there are the same ones I've seen for well over a year now. Any recommendations would be appreciated. Looking to spend no more than $50-80 for the router if that helps as far as a price range goes. Nothing extravagant, just something with good range that won't cut down the bandwith on my cable connection too much.
