Just built this system as in subject with an H100i, it gives a cpu led when I try to power it up. Need it running tomorrow morning. Never seen this before so please help if you can.
Nevermind, it was the bios, I fixed it, I was in panic mode. Now it wont install win7 from a usb stick to my samsun 840pro. Windows says it can't create a partition.
yes it's the only one, I continuously get the error 'windows is unable to create a new system partition...
Wasting so much time. Drive is set to Achi in bios, I can see it in the setup and in diskpart, I can delete, new, format etc. but everytime I click next I see that message.
I think it's because I'm trying to install from a usb key
I'll try that next time, in the meantime - I threw a dvd reader into the system and it installed instantly. Same dvd I made the bootable usb from! Arghh, 1 hour down the drain!!!
