Help with zfs
When you do iostat like that it shows an average value.
If you want current values you need to specify a time interval.
well what im asking is why is the alloc/free blank for my 4tb drives? for example i just added 2 3tb drives and they show data
Code:
               capacity     operations    bandwidth
pool        alloc   free   read  write   read  write
tank        88.0G  19.9T      0  1.20K    987  27.5M
  raidz1    62.5G  14.4T      0  1.08K     61  17.0M
    sda         -      -      0    110    643  6.42M
    sdb         -      -      0    103    443  6.42M
    sdd         -      -      0     78    445  6.42M
    sde         -      -      0     80    466  6.42M
  sdc       8.68G  2.71T      0     60    463  3.56M
  sdf       16.8G  2.70T      0     64    462  6.90M
and what is going on with my space? tank shows 19.9 the raidz1 shows 14.4 and the gui shows 17.2 lol....:confused:
That's just the way iostat displays the info.
iostat is showing how raw data is dispersed across your vdevs.
There is some discrepancy between human readable values and internal values because of the way free space is calculated and file system overhead. If you want human readable value you use the command df -h
How did you create the pool? You said you added "two 3TB drives"...
On my raidZ1 pools they look like this http://pastebin.com/tSuYdPaA
you can do a zpool history and it should give you the commands used to create it.
zpool history z01
History for 'z01':
2012-08-04.15:58:58 zpool create z01 raidz /dev/sdb /dev/sdc /dev/sdd /dev/sde /dev/sdf -f
NOTE: the pool z01 was created on a linux box using zfsonlinux and subsequently moved to a solaris machine. This explains why the device names dont match.
Its almost like you have a raidz1 pool and a mirror which might explain the storage reports as well (the raidz1 pool is 14TB and the mirror is 2.7TB (the size zfs typically reports for a 3tb drive).
SDC and SDF look weird in your report, almost like they are a separate mirror under "tank".
here is the history
Code:
[~]$ sudo zpool history                                            -- INSERT --
History for 'tank':
2013-09-01.15:23:48 zpool create tank raidz /dev/sda /dev/sdb /dev/sdd /dev/sde
2013-09-01.15:23:53 zfs set compression=lzjb tank
2013-09-01.15:23:57 zfs set checksum=off tank
2013-09-01.15:24:02 zfs set atime=off tank
2013-09-01.15:24:05 zfs set primarycache=metadata tank
2013-09-01.15:24:10 zfs set recordsize=16k tank
2013-09-01.15:47:56 zfs set compression=off tank
2013-09-01.15:48:16 zfs set compression=lzjb tank
2013-09-01.16:36:14 zpool add -f tank /dev/sdc /dev/sdf
thanks for the help guys its really appreciated
here is the history
Code:
History for 'tank':
Yeah, looks like you have added a mirror vdev to your raiz1 pool. To expand this pool you would need to add another raiz1 vdev.
something like
zpool add tank raidz /dev/sdf /dev/sdg /dev/sdh /dev/sdi
ok so my 4tb drives are sda,sdb,sdd,sde
and my 3tb drives are sdc,sdf
so i have to destroy the tank and make it with the 4tb drives first like this
then add the 3tb drives on another vdev like this
zpool add tank raidz /dev/sdc /dev/sdf
correct?
will it still be one big pool? i dont want to have 2 separate pools
correct?
raidz needs a minimum of three drives.
so i need to get a 3rd drive for the 2nd vdev to make this work? i have a extra 4tb drive that i was going to add as a spare... should i add it in with the 3tb drives or not because of the size difference?
that should work (i honestly haven't tried this). My pools consist of a mirror (boot), a pool of 7x2tb drives and another separate pool of 5x1tb drives. This configuration works well for me but i understand why you want to add all the storage to a single p ool.
You know you can always test it using files:
Create a bunch of files using mkfile (file1.zfs, file2.zfs) etc.
do something like create 4 2gb files and raidz1 them. then create three 1gb files and add them to the pool.
you can see the results and make sure it does what you want before you do it to your real disks.
ok so i just created the pool again and added the 2 3tb drives correctly and now i dont have access to all my space....
Code:
[/tank]$ sudo zpool iostat -v        -- INSERT --
tank        1.70M  19.9T      0     11    911  14.2K
  raidz1    1.28M  14.5T      0      7    590  8.73K
    sda         -      -      0      3  9.08K  15.9K
    sdb         -      -      0      3  6.86K  15.9K
    sdd         -      -      0      3  6.50K  15.6K
    sde         -      -      0      3  6.81K  15.6K
  raidz1     424K  5.44T      0      4    321  5.46K
    sdc         -      -      0      3  6.83K  20.0K
    sdf         -      -      0      3  7.00K  20.0K
[/tank]$ sudo zpool status        -- INSERT --
  pool: tank
 state: ONLINE
  scan: none requested
config:
        NAME        STATE     READ WRITE CKSUM
        tank        ONLINE       0     0     0
          raidz1-0  ONLINE       0     0     0
            sda     ONLINE       0     0     0
            sdb     ONLINE       0     0     0
            sdd     ONLINE       0     0     0
            sde     ONLINE       0     0     0
          raidz1-1  ONLINE       0     0     0
            sdc     ONLINE       0     0     0
            sdf     ONLINE       0     0     0
errors: No known data errors
[/tank]$ sudo zpool list        -- INSERT --
NAME   SIZE  ALLOC   FREE    CAP  DEDUP  HEALTH  ALTROOT
tank  19.9T  1.70M  19.9T     0%  1.00x  ONLINE  -
[/tank]$ df -h        -- INSERT --
Filesystem      Size  Used Avail Use% Mounted on
/dev/sdg1       286G   14G  258G   5% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
udev            3.9G  4.0K  3.9G   1% /dev
tmpfs           787M  1.2M  786M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            3.9G   80K  3.9G   1% /run/shm
none            100M   12K  100M   1% /run/user
tank             14T  176K   14T   1% /tank
[/tank]$ sudo zpool history        -- INSERT --
History for 'tank':
2013-09-01.20:43:22 zpool create tank raidz /dev/sda /dev/sdb /dev/sdd /dev/sde
2013-09-01.20:45:16 zpool add tank raidz -f /dev/sdc /dev/sdf
2013-09-01.20:46:11 zfs set compression=lzjb tank
2013-09-01.20:46:20 zfs set checksum=off tank
2013-09-01.20:46:30 zfs set atime=off tank
2013-09-01.20:46:38 zfs set primarycache=metadata tank
2013-09-01.20:46:45 zfs set recordsize=16k tank
Code:
  pool: tank
 state: ONLINE
config:
        tank        ONLINE       0     0     0
            sda     ONLINE       0     0     0
            sdb     ONLINE       0     0     0
            sdd     ONLINE       0     0     0
            sde     ONLINE       0     0     0
            sdc     ONLINE       0     0     0
            sdf     ONLINE       0     0     0
History for 'tank':
the fact the devices are listed correctly (raidz1-0 and raidz1-1) looks a lot better.
How much space are you expecting and why?
i dont think "du" is a good tool to use against zfs (use zpool list).
Still not sure about the two disk (raidz1-1) vdev. Perhaps someone else can chime in here as i always thought raidz1 needs 2 disks (two data one parity)
i was expecting to get around 18-20tb
when i made a pool with just the 4tb drives i was getting 14tb thats why i think its not adding the 3tb drives to the pool
and zpool list shows 19.9tb just like iostat
im making a 16tb file to see if it will fit in the pool...technically it should but the gui only shows 14tb free so we will see... at 2gb/s it should be done by tomorrow
You have 4 - 4TB disks and 2 - 3TB disks. Of those, one of each is lost to parity, meaning you would have 15TB raw.
15 TB raw is actually 15000000 MB, When you convert to Bytes (powers of 1024) you get 13,965 GB of space. Round up and you get 14TB
Which is exactly what is reported by df -h
Also you should reset all the tuning you did except for compression. Virtually all those things you changed are shooting yourself in the foot.
Especially reset the recordsize variable to 128, it is not the same as other raid systems, or windows native systems, setting it to 16 will hurt performance unless you are running vdevs of mirrors. If you are going to be using this system for movies and home usage you had best leave the recordsize at the default value.
All that aside, if you could spring for 3 more 3 TB drives and add them to your second vdev that would be ideal.
Ideally best performance is going to be achieved by using vdevs of equal size and performance. By using vdevs of equal size they will fill up equally. By using different sized vdevs you will be restricted to your slowest vdev. meaning for some data you will get the performance of a single drive in your current setup.
You could remedy this and increase performance in your current setup by eliminating your raidz1-1 of 2 - 3TB drives and using a vdev of mirrors instead.
You add a mirror set by using the following command:
zpool add tank mirror sdc sdf
Your original pool consisted of one raidz vdev and two single disk vdevs. If one of those 3 TB disks fails you are facing a complete data loss. Your last configuration seems about right, although I'm not sure what the disadvantage of a 2 disk raidz (I didn't even know that this is possible) is compared to a simple mirror. Remember, you cannot add disks to a RAIDZ, just add a new vdev to the pool.
To get the capacity of the filesystem use 'zfs list', not 'zpool list'. My interpretation is, that the zpool command outputs the total capacity of the disks, without accounting for parity. The 'zpool iostat' command does the same.
Code:
root@quantum:~# zpool list storage
storage    30T  17.6T  12.4T    58%  1.00x  ONLINE  -
root@quantum:~# zfs list storage
NAME      USED  AVAIL  REFER  MOUNTPOINT
storage  11.7T  7.98T   725K  none
While it may not be significant with such a small number of disks, you should stick to 2^n data disks plus parity if you care about space efficiency.
thanks for the help guys im just gonna get rid of the 3tb drives.... now heres the thing i already destroyed the pool and made it with just the 4 4tb drives and started transferring all my data back but i can get a hold of 3 more 4tb drives...should i just add a vdev or should i destroy the pool and make it with all of them at once? from a performance perspective....
You can always just build a pool with your 4x4tb drives now, and add another 4x4tb vdev in the future....
More vdevs = more performance
2 raidz vdevs is vastly greater performance than a single large vdev. Though it comes at a data safety tradeoff.
From a safety perspective you would be much safer to use an 8 - 4TB drive raidz2 pool, it will give you a much more substantial layer of protection in case you need to rebuild.
Ideally if you wanted a *high* performance system you would do 2 raidz1 vdevs of 4 drives each.
Highest performing systems are pools comprised entirely of mirrors.
Most people would say, if you have alternate backups for your data then do raidz vdevs for performance with a mild amount of safety. But if you are trusting this to be your only copy of large amounts of data then do a raidz2
well i can only fit 7 drives on this mobo so its either 7 - 4tb drives in raidz1
or 4 - 4tb raidz1 and 3 - 4tb raidz1 in another vdev
raidz1 is enough protection for me just looking to maximize my space/performance for my home media sever
what would you do?
edit* i guess another option would be to buy a pcie sata card and make a 4 drive vdev when in the future....
If this is for home media, IOPS is not so important, so I'd just go for a single raidz2.
Remember that for ideal performance you want your data disks (N) to be in powers of two, so N+1 for raidz, N+2 for raidz-2 and N+3 for raidz-3
Consider as well a 6x4TB raidz-2, that would equate to four data disks and two parity with a raw total of 16TB storage before formatting, overhead, and marketing losses. Add a seventh 4TB disk to that as a hostpare and you have your seven disk capacity, nice and neat, and requires no intervention from you if a disk should fail.
Ideal performance is not important for a home server. I know lot of people (me included) that use non ideal configurations without any problems.
I would suggest 7 disk raidz2.
While i said performance when i made my first post, it was really just to mask my compulsiveness at needing things to align properly as I stated in another thread :]
