Gaiden133
[H] Ninja
- Aug 6, 2004
I just recently installed the x-fi platinum into my computer, installed the card, I/O drive, and tried to use the remote, but to no avail.
I put power into the I/O drive, connected the red stripe from the I/O drive to the x-fi card. Music is great, and i installed the Creative Audio Console without a problem.
Only thing is that I cannot use the remote nor do I know how to really. I tried using it, but nothing seems to be received.
Under the Creative Audio Console, in the Bit-matched tab, it says for both Digital in and s/pdif-in are "unknown or invalid signal"
Any help?
Any help?
