I set up a media center PC and it's been working fine for about 4 months. One week ago I made a small change. I bought a new HD cage that allowed the addition of another drive and also happened to include a fan on the cage. I put the HD cage in, but did not add a new drive yet. I connected the fan to the chipset fan connector, since I have a passive NB cooler. I may or may not have installed the latest windows updates around that time too. I have 4 HDs, one system, one for TV and 2 for DVDs.
A couple days after the change, I would get live TV freezing. I looked in the event viewer and was getting a lot of disk errors. The errors were for one of the DVD HDs, not the one where i store TV. I tried re-installing my chipset drivers with the latest nVidia. This didnt work, so I replaced my system disk using a norton ghost image I created when i first setup my system. This didnt work, so I assumed this drive had gone bad, so I RMA'd it as it was under warranty. This didnt work either and i'm getting the same errors, this time on the replacement drive (i only get errors on this drive, not the other 3). I switched that drive to a different SATA port and I get the same errors on that drive. Does anyone have any ideas what to try next? Below are my system specs the errors from event viewer:
ASUS A8N-E, 1GB Corsair Value Select, AMD 3200+ Venice, Seasonic S12-430W, eVGA nVidia 6600, Hauppauge PVR500MCE, DVICO FusionHDTV5 Lite
Event Type: Error
Event Source: Disk
Event Category: None
Event ID: 11
Date: 5/16/2006
Time: 8:20:04 AM
User: N/A
Computer: HTPC
Description:
The driver detected a controller error on \Device\Harddisk4\D.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 0f 03 68 00 01 00 b6 00 ..h...¶.
0008: 00 00 00 00 0b 00 04 c0 .......À
0010: 03 01 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: e0 0e 00 00 00 00 00 00 à.......
0030: ff ff ff ff 06 00 00 00 ÿÿÿÿ....
0038: 40 00 00 00 00 00 00 00 @.......
0040: 00 20 0a 12 48 01 20 00 . ..H. .
0048: 08 00 00 00 0a 00 00 00 ........
0050: 94 a8 8c f7 28 bc 47 86 ?¨?÷(¼G?
0058: 00 00 00 00 d0 64 8b 85 ....Ðd??
0060: 00 00 00 00 00 00 00 00 ........
0068: 25 00 00 00 00 00 00 00 %.......
0070: 00 00 00 00 00 00 00 00 ........
0078: 00 00 00 00 00 00 00 00 ........
0080: 00 00 00 00 00 00 00 00 ........
0088: 00 00 00 00 00 00 00 00 ........
Event Type: Warning
Event Source: Ftdisk
Event Category: Disk
Event ID: 57
Date: 5/16/2006
Time: 8:19:57 AM
User: N/A
Computer: HTPC
Description:
The system failed to flush data to the transaction log. Corruption may occur.
Data:
0000: 00 00 00 00 01 00 be 00 ......¾.
0008: 02 00 00 00 39 00 04 80 ....9..?
0010: 00 00 00 00 85 01 00 c0 ....?..À
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 5/16/2006
Time: 8:25:23 AM
User: N/A
Computer: HTPC
Description:
Error code 100000d1, parameter1 0000002c, parameter2 00000002, parameter3 00000001, parameter4 f72e5438.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 64 100000d
0020: 31 20 20 50 61 72 61 6d 1 Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 32 63 2c 20 00002c,
0038: 30 30 30 30 30 30 30 32 00000002
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 31 2c 20 66 37 32 65 01, f72e
0050: 35 34 33 38 5438
Thanks.
Event Type: Error
Event Source: Disk
Event ID: 11
Date: 5/16/2006
Time: 8:20:04 AM
User: N/A
Computer: HTPC
Description:
Data:
Event Type: Warning
Event ID: 57
Date: 5/16/2006
Time: 8:19:57 AM
User: N/A
Computer: HTPC
Description:
Data:
Event Type: Error
Event ID: 1003
Date: 5/16/2006
Time: 8:25:23 AM
User: N/A
Computer: HTPC
Description:
Data:
Thanks.
