help with watercooling setup!
EarlMcFish
I'm going to be building my first watercooling setup in September in my Lian Li V1000B case, and was wondering if any of you have any wc setups in this specific case. I also need help picking out the parts....I could probably do it myself :D but it's also good to see what other people have had success with. Also are there any cpu water blocks out for am2 yet or do the 939 ones work with am2? This will be an am2 7900gtx sli setup, but not right off the bat(will get the other 7900gtx in october).
You should probally use the search function, Lian Li V1000 + WC setups are all over the board. Check users setups out and read your reviews!
