help with video card..... plzzz :(
d1noct
hi, im having some problems with my pc.... i had problems before with it not booting up or getting power or anything and i figured out the motherboard was being shorted by touching mounting things... i used plastic standoffs and now it doesnt have that problem... it turns on shows the option to enter bios and then when its supposed to show the xp boot logo the screen just dissapears and goes to standby and nothing else happens.. the video card is a ati radeon x1600 pro pci-e 512 mb.. aopen nCK804a-LFS with a amd athlon 3700+ cpu... with 1 gig ram.. .also the psu is a 400 watt rexus... like this http://cgi.ebay.com/BNIB-REXUS-SPR-...DVWQQrdZ1QQcmdZViewItem?hash=item300019385490
but when i try a pci video card... (ati radeon 128mb) it starts up and works like a charm.... does this mean it has somethin to do with the pci-e slot or.... i mean it worked 2 days ago
My number 1 recommendation is to get rid of that Power Supply before it goes down and takes your entire rig with it.
I'm almost willing to lay money on that this is a power supply issue.
but if its the psu wouldnt it work if i tried another one??? i tired an ibs one from a pc that similar to this one... same video card athlon 3200+ and it works with no problems so its not that the pc is needing enuff power or something... damn this frustarates mee
think i should just rma the motherboard back since its not working or is anyone goin to help me out
Check the caps on your video card. If one exploded or broke off it wont work.
