Overclock the E6750.
Depending which Quad you buy, you might actually see a loss in performance at stock speeds.
I assume we're talking about PC gaming and 'general' computer use.
If you're looking to spend $150 on your system, you're better off buying another 8800GT and going SLI than you are upgrading your processor.
Thanks,
Yeah after much hand-wringing. I bought a GTX 260 just havent changed my sig. I think I may try my hand at OC'ing it.
