Help with Uninterruptible Power Supply (UPS)
Stuh505
I'm sick of flickering power outages wreaking havoc on my computer and my peace of mind. It's time to get a UPS. Something I've never purchased before so I'm not exactly sure what to look for.
This is my PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
I'm running a Core i7 920 with 12 GB of ram, an 8800 GTS, and four hard drives (300 GB, 2x 500 GB, 1 TB).
It looks like the CyberPower models are pretty good. I'm looking at a 600W or maybe the larger 810W version. Is this how much power it draws ALL the time, or does it draw less power when the load goes down? Will the 600W be sufficient, given that my PSU says 550W continuous?
Edit: noticed my PSU says:
Active PFC: Inceases Power Factor & Reduces Distortion
According to CyberPower,
this makes it incompatible with standard UPS units like the ones I linked above. If your computer has a PFC power supply you
will need to use a Pure Sine Wave UPS or an Adaptive Sine Wave UPS. We make a wide range of Pure Sine UPS models.
Guess I need to do some more research...
I would get a 1200VA to 1500VA ups. You should be able to get an APC SmartUPS XL 1500 on eBay for around $200 for a refurbished unit with new batteries. These are server class UPSs with a lot of runtime and server class protection. I highly recommend them especially for higher end hardware.
The power supply size does not mean the system draws that much power all the time. It's just the maximum the system could possibly draw.
Thanks for suggestion drescherjm. Looks like that unit is quite expensive and I didn't see any cheap used ones selling on ebay (the refurbished one is selling for $500)
I understand that a PSU only draws as much power as the load you are pulling, but a UPS has to constantly charge a battery and this must create an additional load. I've done a bit more research here and it looks like it isn't too bad, only adding on about 10 W or so for some people.
Since the APC model is too expensive I'm now looking at CyberPower's 1500 VA pure sine version...whcih is about $350 shipped.
If anyone knows of a better deal let me know
edit: found it for $308 on Amazon w/ free shipping...bought it!
For those interested, the unit arrived and I couldn't be happier. It's about the size and weight of a car battery...perhaps heavier. Solid construction. The battery came 100% charged and estimates 50 minutes of runtime for my computer, which is unexpectedly high. It comes with a software package that automatically shuts off the PC for you, it is simple and easy to use and gives you interesting power monitoring info. There is a "test" button that shuts off power and it worked flawlessly. Some other users have complained that the fan is too loud. This is simply not the case, I cannot hear any sound coming from the device at all during normal operation, and it did not get loud during the test, either.
