help with tuniq tower....
jaaaaakke
after i install it......it says connect the fan and rheostat to the power supply or motherboard......
im not really sure what the rheostat is...thannks guys for helping out a newb.
oh and is it ok that the tuniq tower has 3holes instead of the normal 4 holes?
Rheostat (aka Potentiometer) = Fan Controller. You can either let the motherboard control the fan speed or use the fan controller to set a fixed speed.
The 4th hole you speak of is for PWM (Pulse-width modulation) control. The Tuniq fan will run fine without it. :)
Hope I answered your questions. :D
And remember, Google is your friend. ;)
