Help with troubleshooting - pc won't start
MrCrispy
My pc - Abit NF-7S, 1.5GB RAM, Athlon XP 3200+. When I boot up, I hear nothing - no power up beeps or POST, nothing on the display. All the fans in the system run and I tried reseating the memory, graphics card etc and disconnnecting everything except the video card, kbd and mouse. Next I tried clearing CMOS by switching jumpers as suggested in the manual and even bootiing without it. No result.
Is this a dead mobo? is there anything else I can try?
edit - PSU is an Antec which I know is not held in the highest regard here. The system is ~3 years old and has never given me any problems at all before. I opened it up today to install a SATA card and wish I hadn't :(, had been running for 2 months!
You can pull everything off it, including memory. It it doesn't beep to complain about a memory problem, it is either the cpu or motherboard.
Good luck!
I was under the impression that Antec made some of the best power supplies. When did that change?
Their power supplies are ok but underperform in gaming applications. Especially over the last 2-3 years. I've had to replace my last 2 antecs because they caused stability issues.
As for the OP's problem though, it could be a number of things. Go over all your connections again, particularly the Hard drives. If a sata cable or sata power connector comes just slightly loose (both slide off way to easy) then it can cause the problem you describe. I had the same thing happen to me just a couple of days ago, thought I fried my PSU but my sata power connector slipped off just slightly and caused the entire PC to fail to boot.
