Help with trading configuration setup
gocanon
Hi
I am looking for a basic system that can drive
1. 3 u2711s in a PLP format with max resolution
2. If option 1. is not possible then just 2 u2711s with maximum resolution and both in portrait mode
The machine will be used for day trading. I have looked at people who provide multi monitor systems and it seems I can't specify I only want dell u2711.
When I am not trading I will use this machine for watching movies in HD and old tv serials
Can you please suggest a prebuilt system. In particular does this setup need high end video card like AMD 7970?
Thanks
Since you have 3 1440p monitors you'll need a video card that can drive them. A single-link DVI isn't enough for 1440p, so the card has to have at least 3 outputs that are a combination of dual-link DVI/DisplayPort. A HD7950 should be good as most have 2 DisplayPorts and 1 dual-link DVI. If you insist on a prebuilt system you'll need to go something fairly big like a Dell Alienware, which are pricey but would have the CPU/RAM/GPU for your needs without having to upgrade.
Thank you rtangwai
Would you recommend any custom built systems? Would they be cheaper than Alienware?
Thanks
Hi
Was wondering if this config from maingear is worth $2300
Thanks
F131 Stock [H77] (system-F131m-H77) $2,360.99
Chassis: F131 with VRTX Cooling Technology
Exterior Finish: Black Brushed Aluminum
Motherboard: Intel® DH77EB Featuring USB 3.0, SATA 6G, Lucid Virtu
Processor: Intel® CoreT i7 3770 3.4GHz/3.8GHz Turbo 8MB L3 Cache HD 4000
Processor Cooling: MAINGEAR Certified Intel® Retail Cooler
MAINGEAR Redline Overclocking Service: Intel® Turbo Boost Advanced Automatic Overclocking
Memory: 16GB Corsair® VengeanceT DDR3-1600 1.5V (2x8GB)
Graphics and GPGPU Accelerator: AMD® RadeonT HD 7950 3GB GDDR5 w/Eyefinity [ENTHUSIAST]
Hard Drive Bay One: 240GB Corsair® Neutron GTX SSD SATA 6G (w/TRIM) [555MB/s Reads]
Power Supply: 600W Corsair® Builder Series 80 Plus Certified PSU
Optical Drive One: 8X Dual Layer DVD RW Drive Slot Loading SATA
Audio: 5.1+2 Channel High Definition Surround Sound (Intel DP55WB)
Ethernet Adapter: On-board Gigabit Ethernet
Wireless Network Adapter: Intel® CentrinoT Advanced-N 6230 802.11n + Bluetooth
Keyboard: Logitech Classic K120 Keyboard
Mouse: Microsoft® Wireless Mouse 2000
Speakers: Logitech Z313 2.1 Speakers with Subwoofer
Operating System: Microsoft Windows 7 Professional 64-bit
Productivity Software: Microsoft Office 2010 Home & Business
The Final Finesse: Designed, Manufactured, and Supported in the USA - Flawless Craftsmanship and Wire Management
Angelic Service Warranty: Lifetime Angelic Service Labor and Phone Support with 1 Year Comprehensive Warranty
