Hi,
I recently am thinking about this mod to power off the mobile rack by switches(toggle type) without opening the case or sliding out all the drives from the rack. After some research I think for a mobile rack that needs 2 molex power, I will use 2 DPST switch, one for each molex.
My question is, is this going to work, I will not flip on/off the switch when the power is on. What happens to sata drives that are connected with no power, I.E., sata cable connected to mobo without power? Do the computer not see them? or will I have problems.
I have my reason/need to do a completely switch off(easier) the whole mobile rack container rather than slide out all the drives.
connect red and yellow wire to a switch for each molex, this will work right?
Will the switch degrade any power that are noticeable, will the drive work fine?
thank you
thank you
