I have a Covad T1 connection, with a Netopia router and a Netscreen firewall, all supplied by Covad. Covad administers both of them, so I have no access.
Here is the problem. At random intervals, during the day, the internet connection will just drop. No ping commands work, as there is no IP address (using DHCP from the router). However, the actual physical connection does not drop. Let me explain a bit further. This is how I am setup:
T1 Line > Covad router > Netscreen firewall > switch/hub (distribution)
I have 3 computers NOT behind the firewall. They are connected directly to the Covad router. When the connection drops, these computers work perfectly fine.
Also, when the internet does work, I ping the firewall. I get massive packet loss:
Reply from 68.164.103.130: bytes=32 time=16ms TTL=64
Reply from 68.164.103.130: bytes=32 time<10ms TTL=64
Reply from 68.164.103.130: bytes=32 time=32ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 68.164.103.130: bytes=32 time=625ms TTL=64
Ping statistics for 68.164.103.130:
Packets: Sent = 69729, Received = 593, Lost = 69136 (99% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1500ms, Average = 1ms
Control-Break
This is pinging the firewall. Why do I get so much packet loss, and why does the internet get dropped randomly for computers BEHIND the firewall, but not for those NOT behind it?
Thanks.
Request timed out.
Request timed out.
Request timed out.
Control-Break
Thanks.
