Hi. I'd appreciate bit of help
I'm trying to make my life bit easier and automate installing WinXP on multiple machines.
I'll begin with what i can't use - can use RIS, because we have freebsd server, not W2k3. So i'm considering either answer files or using sysprep. But the thing is all the computers don't have a floppy or cdrom, just a hdd. Which (i think) rules out using answer files, because the only way you can use them that i know of is copy them on a floppy and use them during the installation.
So i've come to using sysprep - which should be usable in the conditions we have here, but i'm wondering about few things:
1) is it even usable for OEM version of WindowsXP? Is there a way to include multiple product keys in the sysprep.inf? Or how does it work - as i see it, sysprep.inf includes product key for the machine i'm about to sysprep, but that would make it unsable for installing on other machines, which apparently have different product keys.
2) is it possible to use the UDF file with sysprep?
Just few facts about the environment:
-network of approx. 40 PCs atm
-machines with WindowsXP Pro
-no fdd, no cdrom (but available if needed for installation purposes - i can connect fdd,cdrom - i'l like to avoid using fdd, because it'd only cause me to do more swapping (of fdd, as i see it i won't be able to avoid swapping/using cdrom)
-FreeBSD server, so RIS is not a possibility
Thanks for any help/hints you can give.
