noname4498
- Apr 24, 2008
Ok, I have a x-fi prelude hooked up analog to a onkyo HTIB (ht-r520) with the 3 rca to 3.5mm cables for 5.1. The receiver is in multi channel direct mode, shows MLT Direct on the front. Everything works fine except for a ~60ms delay in everything, browser, movies, games, it is very noticeable and annoying. Direct pcm to the receiver over s/pdif has about the same delay, DDL and DTS connect are much worse at over 100ms. I know the delay has to do with audio decoding, processing. Thought using the multi ch inputs would bypass the receiver's DSP and there would be no delay, I just want to use it as a amp, and I don't want to use computer speaker sets after hearing better speakers, I had planned to upgrade the speakers over time to even better ones, starting with the fronts until this happened. I have also had the same problems with the onboard realtek, so its not the soundcard.
Is the receiver likely the problem, because I don't want to get another and have the same problem, I know receivers were not made for computers, but it seems to be the only other option for 5.1.
