Hi, I just built a new system. The specs are in my signature. I upgrade from a [Athlon XP 2800+, 1Gb PC3200 Ram, Geforce FX 5700 128Mb AGP.Running XP pro 32bit] I installed this new system and setup Windows XP Pro x64 Edition. It came with 3dMark06 v1.0.2. I ran the free edition tests and my score was 39xx+40xx+2079cpu I thought this was low, so I did some checking and it said that I was running one vid card. Eventually I found a setting in the Nvidia Control panel to enable Sli. Ran test again same answer. I went to compare my results and found out that I needed to upgrade to a new build of 3dmark06. So I updated all my Nvidia drivers. Upgrade to the new build. Found A setting to set SLi rendering. Enabled that too. Ran 3dMark06 still say one vid card even thought the test shows SLi on the screen from the Nvidia indicator, and and now my FPS are even lower.
I play America's Army, on old system I would get 40-60FPS on 800x600, now in Sli, I get 85 @ 1024x768. However, on some maps, I still run 20-30 when there is ai. Why? Can somebody help me with this. I don't know if it is a bios issue, software, or hardware. The only thing not set to auto is my memory which was read as 5-5-5-18-2t when it should have been 5-5-5-12-2t. I changed the 18 to 12. My bios settings can be found here. Thx in advance for your help. I do not know anything about OCing. or bios for that matter, but this doesn't seem much better than my old Comp.
My Questions in Review:
1. Maybe some hints on best bios setup
2. How to make sure Sli is setup right.
3. Another good 3d benchmark software for free
