whakojacko
- May 4, 2007
I am deciding on cases for a small server build and would like input. Based largely on reviews I have found both here and elsewhere, I plan on going for some Lian-Li case (although other suggestions appreciated). The PC-V1XXX and PC-V2XXX are both too big and too expensive (I am looking at a case budget of max ~$150 and Height<20in). For their compact sizes, I have mainly been looking at the PC-A05 and PC-V600 So I was looking for some help to all the [H] members.
1. Can the V600 (with the odd PSU configuration) fit a zalman 7000? Im not planning on OCing my E6600, but I would like to keep it cool
2. Can people with the A05 USING ALL 3 HD BAYS give me some ideas of temps their setups are getting ?
3. How powerful/Loud are the provided 120s for these cases??
Any other case Recommendations? (Lian-Li midtowers or others) It needs have at least 4 3.5" (including 3.5"->5.25" converters), decent cooling, modetately quiet, and as above no more than ~$150 or 20in tall.
Thanks in advance
Thanks in advance
