help with sata on a p4c800-e dlx
TITAN24
just a few words a wisdom cause i had so many problems with it.
If you want to install your os on a serial ata i follow these directions...
Please go to http://www.asus.com/support/download/download.aspx and get the latest SATA drivers for your MB. There should be a few files and folders for each OS in the ZIP file. Copy all of the files (not the GUI directory if it exists) to a blank, formatted floppy disk.
1. Start with clean, blank drives connected to the SATA Controller. These drives will not show up in the motherboard's BIOS screen.
For a STRIPE array: THIS PROCEDURE WILL DESTORY ALL DATA ON THE DRIVES!
For a MIRROR: You will be asked to copy the information to the new drive. PLEASE BE CERTAIN WHICH DRIVE HAS YOUR DATA. I recommend putting the drive with DATA on it as the primary MASTER, but it can also be the secondary. IF you copy the wrong drive, you will lose your information!!
2. Set up your Array:
On first boot the SATA BIOS should tell you that there are the same number of RAID arrays defined as hard drives connected to the SATA controller. Press {CTRL-S} or {TAB} to enter setup. Delete all of the existing arrays. This will not remove any DATA on the drives yet. Choose between the defaults which should be Security (Mirror) and Performance (Stripe).
3. Boot your 2K/XP CD & start the install.
Once Win2K/XP is setting up, at the first blue screen hit "F6" to load a third party mass storage driver. IF you miss this, you will be warned that there are no hard drives attached. Restart the machine and Tap the “F6” Key a few times as the CD is spinning up. Windows will go through its install routine, then prompt you for an OEM disk for your MASS STORAGE CONTROLLER. Insert the floppy you created in the steps above, and load the first driver on the list. This will let you use your RAID. LEAVE THIS FLOPPY IN THE DRIVE!
4. Let 2K/XP do the partition and install:
Choose install to the empty disk & choose NTFS FULL format, not quick. If you don't have any other hard disks on your regular IDE channels, there can be a LONG pause after the format, be patient.
5. If you had the long pause during install, you will have the same booting into 2K/XP. Once the install is all done, go into the BIOS, then to MAIN, then change "Auto" to "None" for all channels where there are no devices connected. NOTE: This is for your regular IDE channels, NOT your RAID Array.
6. Let 2K/XP do all it's setup routines and updates installed.
7. You will now be able to use your RAID disk as a normal hard drive!
Some good info. I was thinking about picking up a couple SATA Raptors to use my OS on.
