Help With Router Configuration (1841 ISR)
outbreakm
I cant get any computers on the network to connect to the internet. Each computer is getting an IP address, DNS server etc.. Please take a look at my config.
Building configuration...
Current configuration : 1120 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.2 192.168.0.10
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 65.24.0.168 64.24.0.169
lease infinite
interface FastEthernet0/0
description Wan interface
ip address 75.80.*.* 255.255.240.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description Lan Interface
ip address 192.168.0.1 255.255.255.0
ip nat outside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Well I changed int fa0/1 to ip nat inside but still cant connect to the internet.
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
ip dhcp pool LAN
lease infinite
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip classless
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
This is what I have for client using the 1841 with firewall feature set. It works:
ip nat inside source list ICH-LAN interface FastEthernet0/1 overload
ip access-list extended ICH-LAN
remark SDM_ACL Category=2
permit ip 192.168.64.0 0.0.0.255 any
I think you need to change the access list to extended or something.
I usually use pools, something like this:
ip nat pool Guest x.x.x.x x.x.x.x prefix-length 29
ip nat inside source list GuestNat pool Guest overload
interface FastEthernet0/1.50
description Guest Wireless Vlan$FW_INSIDE$
encapsulation dot1Q 50
ip address 10.50.0.1 255.255.255.128
no ip redirects
no ip proxy-arp
ip virtual-reassembly
ip nat inside
What kind of broadband connection are you using? For some reason, I feel like I should be seeing a demand-dial interface here, and that is what NAT overloading should be configured on.
Its basic cable internet from time warner.
There are usually 2 things that can go wrong in these scenario's . Routing or NAT.
Since we are using a single static route we can check routing by seeing if we can ping the next hop and some internet site like 4.2.2.2. Try using the next hop address instead of the interface.
If that is working and you can't ping that same address with an internal user then it may be NAT. Check the nat translation table with "show ip nat trans". Take a look at this link for NAT overloading.
http://www.cisco.com/warp/public/556/12.html#topic5
Something else to check is to make sure you are getting the correct dhcp scope and that address is included in the NAT overload
change 0.0.0.0 route to point out serial interface
change to overload on serial
that should fix it, pending you have DNS servers configured.
I believe the OP said he had a DSL line, suggesting it was plugged into Fa0/0 (description WAN interface) so I don't think setting up anything for the non-existant serial interface will help much there . . . . . :D
Got it to work. Changed the IP address on the WAN interface to dhcp and got rid of the dns server and put "import all"
