Help with RMA from BFG Tech
azrael201
I have an old BFG Asylum 4200Ti that fried when the stock fan stopped working about a year or so ago. I replaced the stock fan with a aftermarket BFG fan to check if it was really dead. Needless to say it was. I asked for a replacement but they said since I replaced the fan they can't give me a replacement...
any suggestions?
Unfortunatley your modification does violate BFG's warrenty status.
BFG said:
BFG Technologies is proud to warrant the original purchaser of the graphics card included in this package ("Product") that the Product will be free from defects in material or workmanship for as long as the original purchaser owns the product, when given normal wear and proper usage. This warranty is valid if the product:
>> Was not damaged while being installed.
>> Was not damaged by software or hardware from a company or individual other than BFG Technologies or by motherboard incompatibility.
>> Was operated in accordance with BFG Technologies specifications, instructions and any technical support directions.
>> Was not modified or damaged by overclocking, tampering, user error, accident, disaster, abuse, misuse, power supply, power application, alteration, repair, modification, a fix or replacement by someone other than BFG Technologies.
>> Third party products, such as motherboards and other system components using this Product are not be covered by this warranty.
You can find the link to their warrenty here.
That said, how dead is it? Are there any leaky caps that could be at fault? If so, those may be able to be replaced to get the card functioning again. Also if you didn't install the new HS pefectly, it may not be making proper contact with the core, and still causing problems. Let us know specifically what's wrong, and who knows, it could be a good chance to learn how to fix your own card.
just buy a new card, you milked the hell out of the titanium time to enjoy games the way they were meant to be played
when my 5950 died i didnt bother rmaing it and stuff because i probably killed it, i aint one of those ppl who would rma somthing they broke, i just pouted for a while, and paid the money for a new card, that was a bitchin card tho, passively cooled 500/1000 mhz goodness :(
QFT, just grab a new card, you could probably pick up another titanium for like what.. $40?
