Help with RivaTuner
UltimaBoB
I posted on the actual Rivatuner forums on 3dGuru but got no help. Seems like this is a common issue now, but I haven't seen any actual responses as to how to fix it.
I have windows XP 32, 9800GX2, Nvidia 174.74 drivers.
When I reboot, RT automatically launches BUT all my fan profiles disappear. It says "fan profile is corrupted" and they are all gone. This happens even with one item on my scheduler so I don't have conflicts / overlaps.
BUT if I exit Riva Tuner and then relaunch they reappear. This is very frustrating as I want to try an overclock but don't dare use RT top do it if the profiles won't stick since then I fear the OC won't stick either.
BTW when I install it says that RT doesn't recognize my drivers. This is RT2.08. So I have forced the drivers in the power users section as is recommended in the various RT guides.
BBTW The people that seem to have this issue the most are all the "x2" GPU users e.g. 9800Gx2, 3870x2, etc... Not sure if that means anything.
Try logging in as administrator and see if that makes a difference.
I was having same problem...just exit rivatuner and restart...fixes it just fine...haven't had any problems and been doing this for the last two months now.
I don't want to relaunch every boot though.
EDIT: what just fixed it for me - or for the last 6 boots - is changing the "run at windows startup" setting from the default "via registry" to "via start-up folder"
