Help with res mounting
Where would you mount a res in this system? I'm tired of the excessive time required for bleeding with the current t-line setup. I'm thinking of the Swiftech Micro Res, but I am open to all options.
My best guess so far is the lower left hand corner of the case. Turn left off the gpu block into the res and then out across the bottom of the case to the pump.
I would mount Swiftech Micro Res near or above your cd drives, that way you'll go out of the res and into the pump. Buy the micro res version that comes with the mounting hardware brackets, that way you can mount it above the drives.
Just so we're clear, the inlet on that pump is next to the t fitting, not the fitting pointing upward. Currently it goes pump>rad>cpu>n/b>gpu>t-line>pump.
