help with replace the fans on the Antec 920
waseem
hello all ,
I have the antec 920 , as you know it cames with shitty fans on the radiator " pretty louad " but they can reach the 2000 rpm i think when they starr to work @ 1200rpm they make a noise ! i"m looking to replace them with a much faster fans but much silent fans means noise less , they are 120mm fans and cams with 4pins for pwm to control via software , any sig ? thanks for help : )
Have used nothing but Noctua fans for a few years now. They come with speed reducer resistor wire sets to fine-tune the sweet spot.
I would personally recommend Gentle typhoon AP-15 if you can find it.. You can run it even at max speed if you want and those fans are hell silent...
If you want PWM fans, then i recommend corsair SP120 PWM the Arctic F12 PWM and noctua NF-F12 PWM.. Both of them are great fans for radiators PWM controlled...
OP, just beware everyone's definition of "quiet" or "silent" is different. I bought some Corsair SP120 quiet editions, and I wasn't happy with the noise until they were down to 5V... at which point they barely moved any air at all. IMHO, there's no such thing as a "quiet" 1500+ RPM fan.
mmm , m just PWM fans and doesn't care for cost i found that antec 920 orginal fans came on 3000rpm speed , so PWM and silent = < so look to buy some thing like Gentle typhoon AP-15 but need PWM , wondering to buy now wich one i will buy :(
