Help with reciever connection
Azsori
I just got a harmon kardon avr 135. I am trying to connect it to my computer via optical connection. I have a hercules game theater xp 7.1. But when I connect my sound card to the reciever, I get no sound. I am able to get sound from other optical devices, such as my ps2. Does this mean that my soundcard isn't outputting the signal properly? I think it I get no sound because the game theater xp isn't SPDIF out. What do you guys think? if it is my card, could you recommend a decent one?
try going into the setting under like my control panel or somin. to make sure the sound is going out the right plug. also (it has happened to me ) check the reciever to make sure u on the right channel ;)
LOL!! I read your reply, and I was like, thanks but I think I would know better than that simple solution. But it turns out, you were right, it was an obscure control setting, lol. You totally schooled my n00b ass. Thanks.
