Makaveli6103
- Feb 23, 2010
I am using 2 2Tb Drives and 2 1Tb drives. When I try to make the pool it gives me an error and in the log it says to use -f command. How exactly do I do this?
Thanks
Thanks
What error, specifically? If it is about the drives being part of a previous pool and you're sure you want to do it, you can go to the command line and use -f (the force option) and enter the command manually. What specific command depends. If you're trying to make a raidz1, likely something like 'zpool create -f XXX raidz device1 device2 device3 device4'
where did you get '-m' from? not from my post?!
