Help with Raid Controller Vista
hoice
I have just built a savage system, everything is running fine except i am new to RAID. I have a P6T7 WS SuperComputer motherboard and it is showing a RAID controller problem in device manager. I have a single 1TB drive running at 7200rpm, Should i install RAID, can i install it now that i have already installed windows? Is this a stupid question because raid can only be installed if you have two drives??!?! thanks for the help.
-hoice.
For RAID 0, you will need to reinstall the OS. For RAID 1, I think that a reinstall isn't necessary. RAID 0 and 1 needs a minimum of two hard drives.
Heh... whats the "problem" in device manager? It sounds like you're just missing drivers, probably for the secondary controller on the board (i'm guessing here).
ya it just says the drivers are not installed, should this be something to worry about, sorry for the newb questions but this shit was really confusing me
not if you're not using the controller. your mobo cd should have the drivers you need, though.
