Alright so here goes...
I have an asus p5w-dh deluxe with 3 74gb raptors, 1 for xp, 1 for games, and 1 for itunes/music (I know this last one is probably excessive but I really don't like the apple software on my main drive for some reason). I also have a Seagate 320gb 7200.10 for storage that is running out of space quickly at the moment.
I want to buy 2 or 3 more 7200.10's and set them up in a raid 5 array. So I'm looking into buying a raid card to set up the raid 5 on but I have a slight problem. I have 2x x1900xt's in crossfire which leaves 2 pci slots and 1 pci-e x1 slot accessable. I really want to go hardware raid but I can't find anything that is hardware for pci or pci-e x1.
The best options I have found are
http://www.newegg.com/Product/Product.asp?item=N82E16816118015
http://www.newegg.com/Product/Product.asp?Item=N82E16816102080
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115029&Tpk=rocketraid%2b2300
LSI 1504064 PCI, Promise FastTrak TX4310 PCI , and HighPoint RocketRAID 2300 PCI-E x1
The big question I have is will the software raid affect me a lot because I'm going to be using raid-5? I have a core2 E6600 running at 3.5ghz with 2gigs of corsair.
If anyone has suggestions on which one of the cards would be best or another card that I have missed it would be greatly appreciated. Thanks.
