help with raid 0 (have never done raid b4)
Okay so I am going to get a new motherboard and new cpu for this winter break since I am going to do some overtime at work. I am going to get the Biostar I45 Tpower motherboard. I want to raid 0 four Supertalent 16gb Masterdrives. Can I run the raid before I install a brand new OS onto it?
I'm still contemplating if I should.
All help is appreciated.
Thanks,
Mark
You will need to setup the RAID before you try to load the load OS.
When you load the OS you will need to F6 the drivers so that the installer will see the RAID Volume.
Ah k cool. I changed my mind about the patriot SSDs, will instead use SuperTalents. Also I am only going to install the OS and certain games that I play a lot. Thanks a lot. I hope everything goes well with this.
Thanks,
Mark
