help with q9550 oveclocking..
tmaven
Hi guys,
i need little help. I have E0 q9550 and i want get max from it. But the most stable oc im still making with AUTO-settings (its stable in prime95 for PICTURE)+ 1,35Vcore(can be lower) + 2,1Vram = 8,5*436=3706 & 1092MHz corsairs.
When i tried some settings change it isnt stable in prime95 (64bit version). Few seconds => one core.. second core.. 3.. 4..
I found some settings from some oc website.. but yeah my cpu isnt same = still errors..
Can you give me some advice or link to some "OCmanual"?
p5q deluxe - bios 1406
this is autosettings.. error
edit: 0/2/3 made the 1024k test in prime.. 1not
8,5*436=3706 - all auto settings
prime @1.272Vcore
core #0 & #2 down after 23minutes..
the others still under prime (2hours)
and how can i check the value of VTT, GTL, NB&SB voltage, which it makes on auto settings?
Try lowering your RAM speed to 1:1 with the BIOS and then get your overclock stable. Once you're done with the CPU, then work on your RAM.
oc done
1st oc profile : 3400MHz = normal use
2st oc profile : 3773MHz = work (noctua is shit :/ cant oc more)
Might consider the S1283. Its nearly as effective as a True for half the price. An E0 Q9550 deserves 4Ghz. The Xigmatek might but your answer. I went with the AC Freezer Pro 7 myself but I must acknowledge the S1283 seems to be a bit better and if I had to do it over would make that choice myself.
