Wicked_Bass
- Sep 26, 2000
I am looking for a great pump that uses 1/4" Id hose or something that I could use with reducers?
TIA
Wicked
TIA
Wicked
headala said:I've heard good things about the Aqua Computer Aquastream and the Innovatek pump, but own neither. Also, a Liang DDC would work well too. You can get the Alphacool version that has interchangeable fittings.
Basically, you need a pump with good head pressure since you're using small tubing.
