help with PSU
category_five
Hi all,
Just wondering if any of you know anything about this power supply. MTBF is listed at 80k hours at 25 degrees C, warranty is 2 years. Unfortunately the model number does not cross reference with anything on Google so I can't find out who the manufacturer is.
• Dual AC input: 115/230 auto selectable 50Hz/60Hz
• Power good: TTL compatible signal out with 100ms to 500ms
• Efficiency: +/-5% at full load (nominal load)
• Operating temperature: 0 to 50 degrees Celsius
• Storage temperature: -20 to 70 degrees Celsius
• Humidity: 5% to 90% non-condensing
• MTBF: 80K hours at 25 degrees Celsius
• Life expectancy of fan 40,000 hours at 40 degrees Celsius
• Dimensions (W x L x H): 150 x 200 x 86mm
• Dual AC input
• Maximum continuous power 500W (PSA500) & 400W (PSA400)
• CE, TUV, UL, ULC/CUL, CB,
• EMI/RFI: FCC Class B, CISPIR 22 Class B Approval
I-star is a common rackmount oriented PSU manufacturer
like Zippy, Etasis, Ablecom, Elan Vital, ect.
they rank behind Zippy which is generally considered the best
but you dont last in rackmount supplies if servers blow up
basic spec compliance and decent reliability is the norm
thats not to say you cant overload a supply of course :p
they assume you know how to figure your needs out and pick the right one though
what you dont see is alot of marketing hype, here are the specs, here is the price
