help with photoshop CS 8.0
oook. i just installed photoshop CS 8.0...and i first was going in to make a picture and i used the gradient tool...i clicked once on my canvas, and the whole program froze, and wasn't responding...so after that i tried a couple more times, did the same thing...then i tried doing simple things like just typing text..and it said something about "cant perform because scratch disks are full"...i have 512 ram, and i didnt have problems like this with photoshop 7.0...so yeah, can anyone help me?
Contact adobe support. They're best equipped to deal with that kind of stuff and part of the price of buying such programs goes towards paying for their quality post sales service.
actually, you want it turned on.
If you use Windows XP, press ctrl + alt + del and that should open your task manager. Then click the performance tab, and PF usage is.
Well, some graphic applications Require the page file to be turned on. And some people opt to disable page file'ing to speed up performance. im not 100% sure if the new adobe photoshop CS is one of these applications that require a page file though.
Assigning scratch disks
When your system does not have enough RAM to perform an operation, Photoshop and ImageReady use a proprietary virtual memory technology, also called scratch disks. A scratch disk is any drive or a partition of a drive with free memory. By default, Photoshop and ImageReady use the hard drive that the operating system is installed on as its primary scratch disk.
You can change the primary scratch disk and, in Photoshop, designate a second, third, or fourth scratch disk to be used when the primary disk is full. Your primary scratch disk should be your fastest hard disk, and should have plenty of defragmented space available.
The following guidelines can help you assign scratch disks:
For best performance, scratch disks should be on a different drive than any large files you are editing.
Scratch disks should be on a different drive than the one used for virtual memory.
Scratch disks should be on a local drive. That is, they should not be accessed over a network.
Scratch disks should be conventional (non-removable) media.
Raid disks/disk arrays are good choices for dedicated scratch disk volumes.
Drives with scratch disks should be defragmented regularly.
To change the scratch disk assignment:
Choose Edit > Preferences > Plug-Ins & Scratch Disks.
Do one of the following:
(Photoshop) Choose the desired disks from the menus. You can assign up to four scratch disks of any size your file system supports. Photoshop lets you create up to 200 GB of scratch disk space using those scratch disks.
(ImageReady) Choose a primary scratch disk.
Click OK.
Restart Photoshop or ImageReady for the change to take effect.
it seems like you don't have enough ram, and i guess from what they say, they don't use Page File space, but rather Physical space, such as a hard drive. My BEST guess is that the scratch disk is set to something that is not there. Perhaps its set to your floppy, CD, or removeable drive.... Instead, i would follow the instructions and try changing your scratch disk to another drive, or make sure that the current drive has enough defragmented space. Eaither that, or consider getting more ram. My "scratch disk" is set to "startup".
Lastly, jsut as a heads up, make sure when you create a new photoshop document, that the settings are not "unreasonable". I mean, don't have it set to a resolution of 3,000,000 pixles/inch ............. just make sure everything is "acceptable" (72 pixles/inch is default)
~Hope this helps, and keep us posted.
yeah...thanks a lot for the help...i think i got it to run now...its still laggy at times...but atleast it doesnt come up with that error
