Help with PC build
Fester
Hello,
The items I have already purchase are italicized and in bold. I’m having difficulty selecting a case and a PSU (wattage & brand). I’m hoping you could help me out with this. This is my 1st PC build.
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
Video Card: EVGA GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 02G-P4-2678-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
Hard Drive: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive Bulk/OEM - WD1002FAEX
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
SSD Hard Drive: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=20-148-442
CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Optical Drive: ?
Case: ?
Power Supply: ?
Questions:
1. Can you recommend a power supply brand and wattage? I know that I need at least 600 watts, but that’s all I know.
2. Is the 3rd part CPU cooler necessary?
3. How much faster will SD drive start windows vs. the HD I have purchased.
4. Are there any internal parts that I may be missing (I have considered 3rd party 120 mm fans but that would be dependent on which case I get).
1) I recommend this Corsair:
$90 - Corsair 650TX V2 650W PSU
2) If you're overclocking, yes a 3rd party HSF is necessary. If your home gets really hot/warm during the warmer months, then yes you should get a 3rd party HSF. Hopefully you are overclocking otherwise you wasted money on the CPU and motherboard
3) Can't really answer that as every system is different.
4) DVD drive? What OS will you be using?
Case wise, I recommend any of these cases:
$80 - Corsair Carbide Series 300R ATX Case
$95 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
$105 - Fractal Design Define R4 with Window Arctic White ATX Case
$105 - Fractal Design Define R4 with Window Titanium Grey ATX Case
$110 - Fractal Design Define R4 with Window Black Pearl ATX Case
$110 - Fractal Design Define R4 Arctic White ATX Case
$110 - Fractal Design Define R4 Titanium Grey ATX Case
$110 - Fractal Design Define R4 Black Pearl ATX Case
$110 - Corsair Carbide Series 500R ATX Case
$119 - Corsair Carbide Series 500R ATX Case
$120 - NZXT Phantom PHAN-001BK Black ATX Case
$120 - NZXT Phantom PHAN-002OR Black Finish w/Green Trim Full Tower ATX Case
$120 - NZXT Phantom PHAN-002OR White Finish w/Red Trim Full Tower ATX Case
$130 - NZXT Phantom PHAN-001WT White ATX Case
$130 - Lian Li PC-7HX Black Aluminum ATX Case
$140 - Antec P280 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$140 - Corsair Vengeance Series C70 Arctic White ATX Case
$140 - Corsair Vengeance Series C70 Gunmetal Black ATX Case
$144 - Silverstone RV03B-WA ATX case
$160 - Silverstone TJ04B-EW ATX Case
$160 - Thermaltake VN300M1W2N Chase MK-1 ATX Case
$160 - Corsair Graphite Series 600TM ATX Case
$162 - Corsair Obsidian Series 650D ATX Case
$178 - Silverstone RV02B-EW-USB3.0 ATX case
$180 - Corsair Special Edition White Graphite Series 600T ATX Case
$230 - Silverstone FT02S ATX Case
$230 - Silverstone FT02B ATX Case
$240 - Silverstone FT02S-W-USB3.0 ATX Case
$245 - Corsair Obsidian Series 800D CC800DW ATX Case
I have two additional questions:
1) Are internal memory card readers obsolete?
2) Do I need a sound card?
1) Most internal memory card readers are still of older designs that are only capable of USB 2.0 throughput while an increasing number of external card readers have a USB 3.0 interface. Very few USB 3.0 internal card readers, if any, are available at all since internal USB 3.0 connections on existing motherboards are still relatively rare - and most of the USB 3.0 internal card readers that are currently on the market still require an external connection from a rear expansion slot backplate to a rear USB 3.0 port (this makes for a messy, cumbersome connection).
2) Only if you have really good speakers or headphones and really good audio media source material. If on the other hand most of the audio output is from online Websites such as streaming services, on-motherboard audio will suffice.
