Hi,
Recently bought a NAS (Synology DS212j), upgraded to a gigabit router (Netgear WNDR3700), and now want to utilize the pre-wired ethernet ports in our condo. However, no idea how to do this last part.
Do i just plug one of the LAN ports from the router into the wall using a Cat5e cable?
Then the signal will be routed to all ethernet ports through the patch panel?
I located a patch panel in the closet, but not sure if its wired correctly or which connection goes where. I took some pics that you can see here: http://imgur.com/a/2R035#0
you can see in one of the pictures that some of the cables are only connected at one side.
thanks for any help!!
