rozarsmahkco
- Jun 4, 2006
I recently built my first SFF using the setup in the title plus a NT-06 cooler. When I check my cpu temp in the bios is reads 50C. I would appreciate any advice on lowering that to a more acceptable level. I have the case open right now with 3 80mm fans installed. I'm going to try turning Speed-Step on to undervolt the CPU.
Secondly, I was wondering if anyone has experience with the front panel sound connectors. The description for the jumpers do not match the labels headers from the case connectors. For excample: the bios lists (in ac97 mode) certain jumpers are NC. What does NC mean. There are headers that are labeled Line out-R + line out R ret. whats line out-R ret?
Thanks for all your help.
