Option 1
HIS X1800GTO IceQ3
- 200 euros
- excellent cooling design
- 100% unlockig to 16 pipes
- Able to reach X1800XT Speeds via voltage modding using ATI Tool
Option 2
Sapphire X1800XT
- 225 euros
- somewhat worse cooling
- Stock 16 pipes, guaranteed 625/1500 speeds
I know X1800GTO from HIS can be flashed with an X1800XL bios from Sapphire to unlock 16 pipes which also allows for changing voltages via ATI Tool with another simple trick allowing the card to reach high speeds. Under windows this card looks a cheaper X1800XT with better cooling.
However I don't just use windows so I'm wondering how it could be possible to modify the bios so that the default clocks and voltages would be set from the bios by modding it to run at specified clock speeds (eg. 625/1500) and voltages, so I don't lose much performance (default speeds for his is 520/1000) ?
HIS X1800GTO IceQ3
- 200 euros
Option 2
Sapphire X1800XT
- 225 euros
