Help with overclocking p4 2.66 ghz...
ElementK
Hey [H]ard forum overclockers!
I'm an OCing n00b, and I need help. My poor little TI 4200 won't exactly make DOOM 3 the best it can be---so I want to overclock my processor to help it out a little. Heres my deal: It's a p4 2.66 with PC2700 DDR and stock cooling. What can I do to overclock it? Is there a guide? Also, what's the meory frequency and CPU voltage do?
Thanks a lot!
I currently have a 2.66B OC'd to 3.1GHz at 1.535v with a Zalman 7000A-Cu and AS5. With the stock HSF I would imagine you could achieve a stable/not too hot overclock at about 2.9Ghz, I ran mine with a stock cooler like that with no problems, but check your temps at idle, and then download Prime95 and check them under 100% load to make sure.
Sejin
