Help With Overclocking Intel Canterwood i875P
Jager673
Ok well i want to overclock all of this and i dont know what to do in BIOS and such to overclock my CPU and memory and all that.
Here is a List of some of my Mobo stuff...
Version EVEREST v3.50.824 Beta
Benchmark Module 2.1.169.0
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer
Generator
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2007-01-24
Time 01:43
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Pentium 4, 3200 MHz (16 x 200)
CPU Alias Northwood HyperThreading
CPU Stepping D1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 3200 MHz
Min / Max CPU Multiplier 16x / 16x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Multi CPU:
Motherboard ID DELL Dim XPSGEN2
CPU #0 Intel(R) Pentium(R) 4 CPU 3.20GHz, 3192 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.20GHz, 3192 MHz
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 89.0 W (depending on clock speed)
Maximum Power 49 - 109 W (depending on clock speed)
The easiest way to overclock is to increase your FSB speeds. You'll have to go through all the screens in your DELL BIOS to see if there is anywhere you can increase the FSB. You will also need to LOCK the AGP/PCI bus speeds (66/33). You will also need to locate the CPU:RAM divider adjustments, as well as CPU and RAM voltage adjustments.
Hopefully, since its a DELL XPS system, the BIOS won't be"crippled" like the BIOSes found in the Optiplex or Dimension series.
Does DELL have a forum area? That may be the place to start your research.
Good Luck.
