Help with old(er) motherboard?
MiG29TangentBoy
I'm setting up a computer for my wife, and I'm using my old overclocking champ, a trusty Abit NF7-S 2.0 board. After installing WinXP and the chipset drivers, it won't recognize the onboard LAN. It's as if it doesn't exist. If I plug a cable into it, it lights up...but no dice when I tell Windows to search for drivers. Network Folder shows a 1394 Adapter available (whatever that is...), but nothing else. What gives? Am I missing something simple or what? I don't see a setting in the BIOS to enable it, I'm at a loss for words. Help!! :eek:
- Did you look at the mainboard's manual?
- What does the Device Manager say?
Device Manager shows nothing at all...no little yellow "!" or anything. Manual has nothing useful. It should just...work. Lan Controller is enabled in BIOS, that's all I see there addressing the LAN.
So confused...I know it worked perfectly when I replaced it with my A64 setup. Maybe it's jealous? :confused:
If you've enabled the NIC in the BIOS and Windows doesn't see it, you've either got a resource conflict, or the NIC is dead.
I'd just use a $5 RealTek NIC and stop worrying about it :)
I used to have the same problem that you're describing with my old nf7-s rev2.0. I found that by uninstalling the mobo's drivers and reinstalling them I was able to fix the problem.
Sheesh. Weird stuff. I uninstalled the drivers that were from the board's install disk and tried reinstalling nvidia's latest ones. It insisted on DirectX 9 before proceeding, so I got an ethernet card to get the internet access to allow the download. Then after the 5.10 drivers were done, voila! My ethernet is back, and I have a random backup card for future surprises.
I still think that my NF7-S is jealous and cranky. My wife and it will get along just fine. Thanks for the help, guys! :cool:
