Help with nvsurround portrait!
Phishy714
Google is not being my friend today.. but can someone give me a link or quick run down on what I will need to do to setup the correct resolution and settings for portrait mode?
I got my hands on 3 - 120Hz monitors and will be doing some debezeling when my stand arrives. Thanks!!! pics to come.
It is a supported mode for nVidia (finally) but I don't think it's in widespread use. It should be as as simple as selecting the portrait resolution. It won't work in 3D Surround though - just a heads up.
yeah I wasn't going to use 3D.. I think it's a gimmick at best.
But that's good to know that it's supported. Does this mean that when Nvidia updatestheir drivers and updates surround stuff, they add profiles for portrait mode as well?
I thought so too till my gf got me the Asus 27' 3D monitor. AMAZING. I love it so much. But as for your setting, you just set up the surround group and then under Display just click rotate displays and you should have all 3 monitors on the right, click and rotate each one.
As far as I'm aware, it's always been a supported mode on NV hardware, I remember members of OCAU (Overclockers Australia) running portrait mode in NVS when the system was released.
