I'm at my wits end and hope you guys can help. About a month ago my rig started having problems booting. It would power up, and a few seconds later power down. No BIOS screen. Fans and drives all spun up. However after repeating this cycle several times, it would come up.
I finally took it apart and found that one of the cheesy pushpins that hold the HSF on the CPU had come loose and therefore the 'contact patch' was very bad. Fixed that, but the problem kept getting worse. Finally it won't boot at all.
Symptoms: Hit the power switch. drives spin up, fans spin up, but no BIOS. And when I hit the reset button, it powers down(!) and then back up a few seconds later.
So I have:
Cleared the BIOS. No change.
Disconnected all drives. No change.
Replaced the 650W Antec power supply with a new 500W power supply. No change.
Removed all cards except video. No change.
Replaced the stock Intel HSF with a CoolerMaster MARS. No change.
Replaced the CPU (C2D 6700) with a Celeron-D 325 from another system. No change.
Removed the Video card (8800GTX) and replaced with old PCI video card. No change.
Replaced the MB (ASUS P5B Deluxe) with identical part. No change.
Removed the RAM. No change.
Disconnected all the USB/1394 ports and cables. No change.
Replaced the Power Supply AGAIN with a new Silverstone 850W unit. No change.
That's all I can think of! Anybody have ANY ideas no matter how crazy? I am going NUTS! There is nothing left to replace! Hope somebody has an idea!
TIA!
ThePP
So I have:
TIA!
ThePP
