I work for the ITS dept on campus, and we have ~300 Cisco Aironet 1200 Access Points all over campus. Well, each one of these things is about $600, so we have a piece of cable attached to their mounting brackets to keep people from casually stealing them. Well, we're going to start pulling them all down to upgrade them to 802.11b/g and we don't want to put them back up using the current cable/crimp method.
Right now, the cable loops around one of the strong main runs of ceiling supension and then through the bracket. The AP is secured to the bracket, and the bracket is secured to the ceiling channel.
The problem with the current method is that we have to cut the cable to get them down for service or whatever, and I was hoping someone had a better idea about how to secure them up there.
I was thinking about some kind of barrel lock with a key, or a security hex screw so we can take them down easier. I was thinking about using some kind of throttle linkage for a car or lawn mower, but I couldn't find one that was 1/4" to fit the cable diameter. Any ideas?
