Hi guys firstly im new to HF so Hello everyone!
now the etiquette is over I need some help deciding a few things with a new rig im planning to put together end of January.
my current rig setup is :
haf 932 case all fan holes replaced with sharkon 2000SE including the drive bays and bottom intakes.
all case fans are intake except rear.
AMD Phenom II x6 1090T overclocked to 4.0GHz and six cores are manually unlocked
cpu watercooled with corsair h100i fans where replaced with push pull sharkon 2000SE
16gb corsair xms 3 I think not 100% cant remember dual channel ddr 1333mhz not Oc'd
corsair formula IV socket am3 890FX
2 x Asus direct cu II HD 6970's ulps deactivated and both overclocked safely at cpu clock : 960MHz HPM Clock at 1450 MHz and a slight increase in power sent to the card.
and finally a cooler master GX 850.
Pc gaming – Web Development – SQL Development – Adobe master Collection – Graphic Design – advanced Algorithm procedure.
Roughly end of day budget £2500 UK GBP
Scotland UK
colermaster cosmos 2 UT case I will be replacing all fans and filling all vents with Corsair SP120 with red the main reason im going for these fans is to keep a visual style inside black and red.
AMD Piledriver FX-8 Eight Core 9590 with a custom water cooler that im currently working in which is 240 mill thick grill with sp120 doing a push pull which will be top positioned on the case as intake. planning to overclock this to around 5.2ghz
SuperFlower Leadex Platinum 1200W psu
Asus Crosshair V Formula Z AMD 990FX am3 mobo
Corsair Dominator GT 16GB 4 sticks at 2133mhz I may mess around with req's but not important for this.
and 2x Asus Radeon R9 290X DirectCU II will be overclocking these but don't know what to yet.
ill also be adding a 200gig ssd just to hold the os so my current hard drive will just be software and media.
My current Sata drive
And possibly my 2 x direct cu2 hd6970s
6) Will you be overclocking?
Yes cpu - ram – gpu and a few other bios & softside tweaks & hardware tweaks.
2560 * 1600
End of january
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
RAID, crossfire and 6gbs sata
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
64 bit win 7 moving to win 8 possibly don’t currently own win 8.
so my first question is the case is the cosmos really better than a haf x when all air vents are filled as I think the haf x may have more options but im undecided wether to go tihe the cosmos 2 or the haf x but I do need a lot of internal space as im planning to add a third card and modify the water colling system to incorporate the mobo , gpus and ram.
my second questions is about the graphics cards. id like to hold off spending £1000 on getting the two cards for now and perhaps keep my 6970's just until they come down in price a little. so does anyone have a similar system to the one im buying but with similar cards to the 6970's and how does it run will there be a significant increase in performance when gaming?
also im being forced to migrate to windows 8 for testing reasons with my work whats peoples experiences with win 8 when gamming is it worth it or should I double boot?
and that's it im open to any other input anyone might have regarding the new rig Thanks!
Scotland UK
2560 * 1600
End of january
