After living out of the country for 2 years, I have returned home 3 weeks ago and have been doing some research to replace the rig in my sig. I am going off to college on the 13th and need to have my new comp done before I go so any help, suggestions, or comments with the following build would be GREATLY appreciated.
After all of my researching, this is what I have think I want to get...
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail $308 I have chosen this with the hopes of being able to overclock it to at least 3.0Ghz.
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express ATX Intel Motherboard - Retail $116
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail $149 after rebate
Antec LifeStyle SONATA II Piano Black Steel ATX Mid Tower Computer Case 450Watt SmartPower 2.0 Power Supply - Retail $70 after rebate
EVGA 256-P2-N636-AR GeForce 7950GT 256MB 256-bit GDDR3 PCI Express x16 HDCP Video Card - Retail $185 after rebate
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM $85
Acer Gamers Line AL2051W Black/Silver 20" 8ms DVI Widescreen LCD Monitor 300 cd/m2 800:1 Built in Speakers - Retail $249
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner with LightScribe - Retail $50
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM $110
Ok...I have some questions...
1. I was reading about Windows Vista and how the OEM version cannot be transferred to another computer...so does that mean if I buy a new motherboard and a new proc later on my OEM copy of Vista will be useless?
2. The E6600 is a 1066 FSB processor. Will running my RAM at only 800 affect my performance?
3. The video card I have selected is not DirectX10 compatible. I am an occasional gamer and am not sure if it is worth it to spend more money to get one. Is it worth the 100-150 more to get DX10?
4. As I said earlier I would like to overclock and am wondering is the Antec 450 watt PSU will be capable of it. Will this be good enough to run this system and if so will it be good enough to OC?
Alot of questions I know, but I really would like to make a good purchase because this comp has to last me a couple of years. Thanks for your input.
