chockomonkey
- Oct 11, 2003
I have two separate computers which are both experiencing the same retarded shenanigains with regards to Microsoft's .NET framework.
Each computer had an update from Windows Update for .NET 3.5 which was had been failing for a long time for months.
I decided to try to fix the problem today--after much googling, i was led to believe that in order to fix this, i'd need to uninstall .net framework altogether and start fresh. So, i found a piece of software called .NET Framework Cleaner and got (to my knowledge) all versions of .NET off.
I had assumed that with a system "clean" of any .NET framework that windows update would see its absense and help me install all needed versions. This, however, was not the case--instead, windows update didn't notice it at all, so i have no pending update or installs of this framework.
Trying to scour the net, i can find the latest redist. from microsoft of 4.0, but (again from googling) i'm led to believe that i need multiple versions of .NET framework. Is there a way to install them all at once?
I can't believe how difficult this whole .NET thing has been, i don't know why Microsoft hasn't made this standard easier to see, service, etc... what a pita!
Thanks for any help,
Cheers
Cheers
