Deathwish238
- Oct 11, 2006
I'm running Windows 7 64 Bit Ultimate. All updates are installed. NOD32 is my AV.
I cannot run any programs that use .NET 4. For example, the Unigine Heaven Benchmark: http://unigine.com/download/
Any .NET program I run gives me the same error:
.NET Framework Initialization Error
To run this application, you first must install one of the following versions of the .NET Framework:
v4.0.30319
Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework.
I have installed, ran the .NET verifier, uninstalled and ran the .NET cleanup utility a dozen times. I have tried .NET that comes with programs, the client version from MS, the full version from MS. It doesn't matter, the result is the same. I have checked that .NET registry keys are showing up appropriately and it shows up in add/remove programs as well. The .NET install completes without errors each time.
.NET version Used: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=24872
Verification Tool Used: http://blogs.msdn.com/b/astebner/archive/2008/10/13/8999004.aspx
Cleanup Tool Used: http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
v4.0.30319
