Help with multiple inputs on a ZR24w
HyperTension
Sigh.... Really like this monitor, first transition from a CRT and it has been a great transition for everything 'net / gaming related.
Ran into my first issue with this. I have an LG670 for a player but my TV (RIP beloved LG LED LCD....) became a bit damp due to 2 y/o and apple juice.. needless to say, it's going to be a while while TV is getting warranty work done. I decided to run the blu-ray to my computer screen via HDMI to DisplayPort Adapter.
No joy. When I have it plugged in at the same time as my DVI, I do not get any type of signal at all. When I run it to my monitor via HDMI-DVI adapter, I get the "signal out of range" error, with a recommend setting of 1920x1200 @60Hz. Thats what my monitor is already set at via nVidia Control Panel.
Any ideas or suggestions are more than welcome at this point. Current Drivers are 275.33 if that helps at all.
You're gonna be bumping for awhile, I had the same issue with my ZR24w and couldn't figure it out. Wasted money on an adapter just like you did and could never get it to work. As far as I can tell the DisplayPort input will only accept a direct DP input, not hdmi -> dp or anything else. I could never get my PS3 working without a dvi/hdmi splitter going to the only DVI input. Your best bet might be to get some sort of active switchbox with dvi/hdmi inputs/outputs and use that.
Well... that sorta blows goats.... I'll do some more research and I'll post if I can find anything positive...
